Forum: Old versions
Topic: RAM?
Which is the minimum RAM memory necesary for atomixmp3 run 10 pts?
Sorry for my english, I hope you can understand my question.-Saludos,
Dj Coc "Argentina"
geposted Mon 18 Feb 02 @ 5:04 pm
It depends on your OS, your hardware and other software you want to run. On my PIII@500, 256 MB is a bit weak with new visualisations from Winamp beta 3 and on-the-fly-encoding, so I upgraded my system to a 1,2GHz Athlon, but left the RAM. Now it runs all smooth on XP prof.
The speed of the processor is likely to be far more important than the amount of RAM. Having said that, 64MB should be quite adequate for Win9x/ME, and 128MB for Win 2K/XP.
Cheers...
Swift
I agree !
But you don't need tons of RAM as long as you are running atomix alone (no virus scanners, other programs, etc).
64 is the bare minimum, 128 is just fine.
