Forum: Old versions
Topic: Phono mixer inputs
DJtalonHome userMember since 2001
I have a 4ch mixer. Only two of the inputs are line-level, the other two are at the level for a record player.
Is there any device I can get that would let me plug in a line-level input into these sources?
geposted Wed 20 Feb 02 @ 4:58 am
Basically the phono inputs are the same as a 'line' input, expect the phono inputs have an extra pre-amplifier, as record players only output a very small voltage. If you have the output level of your sound card (or whatever you want to plug into the phono input) set really low (and by really low, I mean practically turned off), you might be able to get away with it. Otherwise you'll need to attenuate the signal before putting it into the phono source. You could do this, but would end up with a fairly lousy signal to noise ratio, and therefore probably wouldn't be worthwhile.
Cheers...
Swift
geposted Wed 20 Feb 02 @ 7:14 am
DJ JimHome userMember since 2003
Radio Shack used to sell a line level attenuator that looks like a RCA to RCA connector. I used them for recording on a recorder that didn't have a line in. Maybe you can find some on the internet.
If not here's a web site that has plans to make them:
http://www.hut.fi/Misc/Electronics/circuits/phono.html
Hope this helps,
DJ_JIM
geposted Thu 21 Feb 02 @ 4:04 am
