Forum: Old versions
Topic: Setting Up Cue
Hello,
Even with the newer version there is now way of easily setting up a cue point exactly where I want it. No way to pause & back up just the slightest bit or go forward just sligthly. Is it different in the real version (I'm using the demo)?
That's probably the only thing that would prevent me from using this program for live events.
geposted Tue 26 Feb 02 @ 12:35 am
In the full version you can move the cue FORWARD by clicking on the wave display and dragging. It will only back up slightly and not at all past a marked cue point.
So select the player you want to cue and, using headphones, pause the play just before the point you want. Then drag the wave forward to the exact point and mark it with the CUE button, hit STOP and you are cued.
I have put in about 16 hours of live use now with this program, works great.
