Forum: Old versions
Topic: No, EQ effects while monitoring though headphones...
I'm sure this has been asked before. The whole pt of the Eq is to use it to make the beat of track B sound like that of A and then mix across and everything is sweet.
But the Eq effects when enabled aren't applied to the channel that goes to the headphone. They do work however when played through the main output.
I'm currently using 1 soundcard (3d) Sb Live!
Technically I guess I can see why this doesn't work, because Atomix is applying the effects to the main channel and not the rear channel.
Am I correct in saying this? Or is there a solution?
I'm planning on getting an external mixer (the new behringer vmx 200) and another soundcard. This should fix my problem right?? I'm pretty positive but some reinforcement from others would be nice, LOL. Also when you get a mixer, can u use the diff headphone previews, like all channel A audio (ie only the song playing on deck a) and only the audio from channel b and both at the same time. I really need this, and I know its standard with turntable / mixer setups.
Thanks guys for all your help.
Dj Big Kev
geposted Tue 26 Feb 02 @ 4:56 pm
Hello,
Your problems would be soleved when you plug-inn a second soundcard and use a mixer.
This is the prof. setup, you will love it.
Grtz
Thanks mate. So the diff audio previews work too??
I have the same problem, only I am using two soundcards. The second (headphones) channel does not reflect any changes to volume level, gain or EQs. For that matter, even my main channel does not reflect changes to EQs. Can anyone help?
I think I realized the problem -- I had hardware mixing checked in my sound settings, so the 2nd output channel was not affected by any changes in the EQs. However, I still have the volume problem.
