Forum: Old versions
Topic: What happened to the db function
I just downloaded the new version and one of the main features I used on the old version is the volume level meters. Since Mp3 are recorded with different volumes, I needed to know what they were to make adjustments before decoding to record CD. Is the feature still here and hidden or been removed from the new version?
geposted Sun 03 Mar 02 @ 5:50 pm
If you´re talking about the volume sliders, they´re still there, but now as extra sliders, depending on the skin.
Why don't you just use the auto gain feature?
-MixMasterMatt
I don't mean the volume sliders. The gain buttons are a temporary change while the songs are playing. The old version had a actual read out of the volume of the songs, ie -20,-27, -18 etc. I could then go to another program, edit the volume up or down, go back to Atomix, check the results so each song was at the volume I wanted before burning to a CD. This feature is missing from the new version.
Try to click in the desk monitor to change the view to details.
