My music seems to sometimes when I use AtomixMp3 sound like shit, it sounds like my speakers are broken, and I tested with headers but it sounded as bad as it did with the speakers, this is sound that the usual person maybe wont hear, but as DJ you? and I now how irritating that little bad sound is. anybody know why it sounds a bit bad? I guess it something with my computer.
And another question, I got AtomixMp3 2.0 and when I choose speakers and headers the right speaker in my header just stops playing.. why?
greatful for answers!
Thanks for the best mixing app out there!
"DJ MAg" - Your Steps on the Dancefloor!
geposted Thu 07 Mar 02 @ 7:16 pm
You have to disable an option ... think it is the option wich keeps the beats always the same (dunno the name exact, sorry)
for your second question, are you sure you have 2 soundcards or a 3d-soundcard ????
geposted Thu 07 Mar 02 @ 9:46 pm
Which soundcard do you have? In same cases the problem is with the sound card.- I had a Genius SM Live 3D and I had to change it for a Sound Blaster Live 5.1., and I can fixed my problem.-
geposted Thu 07 Mar 02 @ 10:58 pm
The sound problem is proberly just the gain that's too high.
When the gain is too high the soud is the way you discribed.
Grtz Salva
Grtz Salva
geposted Fri 08 Mar 02 @ 11:22 am
dodgy soundcard
or as somebody said, the sounds r too overdriven [loud]
geposted Fri 08 Mar 02 @ 7:55 pm
