Hello
I just downloaded the trial version of Atomixmp3 and I noticed that the Windows added languages ( in my case Greek) do not display correctly. This problem was also in the previous version.
Is there an option (eg. Registry) to use the default Windows fonts instead of using the built in font of Atomix mp3?
Regards
Silkman
Regards
Silkman
geposted Sat 16 Mar 02 @ 9:41 pm
Sorry I forgot to register
Silkman
Silkman
geposted Sat 16 Mar 02 @ 9:43 pm
1. With notepad open the xml file from the skin you usualy use.
2. Go to the search option, of notepad, and search for "tahoma". This is the font for atomix using.
3. Replace this font to a deferent font which support greek language, like "arial greek".
4. Replace all "tahoma" with "arial greek"
5. Save us the new file in xml format and thats it.
geposted Sat 16 Mar 02 @ 9:51 pm
WIN ME, 98: If you have problem with Greek characters, just add this line in the win.ini file under FontSubstitutes: Tahoma,0=Tahoma,161 Also, keep the original language.xml in a deferent folder and then copy the Greek language.xml in atomixmp3 folder.
WIN XP, 2000 : http://www.atomixmp3.com/forum/display.html?forum=6&topic=471
geposted Sun 17 Mar 02 @ 10:17 pm
