Forum: Old versions
Topic: Does Atomix support Roland UA-1A USB audio device?
Before I download the full version of Atomix, I need to know if it supports the Roland UA-1A USB audio device.
Which set up would I choose in the Sound Configuration?
geposted Wed 03 Apr 02 @ 6:54 pm
Well, does it?
Can't anyone at Atomix tell me about their own software?
I personnaly don't own this soundcard so I don't have to answer !AtomixMp3 use directx and has no direct access to the hardware ! We are only using an interface between hardware and the software called directx 8.1 librairies !
Try to see if this car is 100% compatible with directx.
Difficult question, because i decided not to buy the UA-1A,
I've decide to buy the Soundblaster Extigy.
Doesn't it work with the 2.1 demo?
Because the main functionality and the drivers of the demo are the same as the payed version.
So, i'm curious as well
Dj Appie
I have bought the full Atomix 2.1 and still cannot get the headphones (using the headphone socket) to cue without the track coming out on the speakers as well.
Surely there must be a way?
