Forum: Old versions
Topic: The Automix-feature beatmatches too often
I know I've seen a post here about the fact that when automixing both tracks are beatmatched several times per second which causes more harm than joy (pumping the beatmatch like that makes it go in and out of sync constantly)
What was the registry key you had to change to make it beatmatch less often, so that if it actually gets in sync it stays there?
(I've tried the same procedure manually and beatmatching constantly makes Atomix "confused" as to what is a beat and what is in between beats, doing it less often makes it more reliable)
I know it was something about a 14th's of a second-value that had to be altered to one of the keys in \hklmsoftwareatomix but I can't find the aporiate key there and I can't find the original post... believe my, I've tried searching for old posts on that subject :oP
geposted Sat 06 Apr 02 @ 7:21 pm
