did atomix support USB external sound cards?
and which one?
and which one?
geposted Tue 09 Apr 02 @ 8:49 pm
Yes all of them but in full 2,1 version.
geposted Tue 09 Apr 02 @ 11:27 pm
SB Extigy is well supported.
geposted Fri 12 Apr 02 @ 12:07 am
yeah all of them are supported by ATOMIX
geposted Fri 12 Apr 02 @ 6:44 pm
Ok, the Sb Extigy is supported,
But when I select the 3D option in sound configuration and use the front output for the speakers and the rear output for the headphones, the system crashes after a while.
The system works fine if I use the dual soundcard option.
(speakers connected to the front output of the SB Extigy and the headphones connected to the internal soundcard.
Do I do something wrong here?
DJ Appie
DJ Appie
geposted Sun 14 Apr 02 @ 3:55 pm
Doesnt crash on mine..... sorry I can't help but it's exam week!!!
geposted Tue 16 Apr 02 @ 3:47 am
SAme HERE !!!!!!!!!! I HAVE 3 EXAMS TOMMOROW AND LOOK WHAT I AM DOING HERE !!!!!
geposted Tue 16 Apr 02 @ 4:09 am
yeah, im actually IN a business class presentation right now... talk about time management lol
geposted Wed 17 Apr 02 @ 11:55 pm
yes it does. I use a M-Audio quattro. but it doesn't detect the second pair of outputs ...
geposted Thu 25 Apr 02 @ 9:42 pm
Somebody mentioned that the sound quality was better when using two-soundcard-option than using 3D-soundcards in 3D-mode. Have you guys experienced this?
Is Extigy a good solution if you want to use it with an external mixer? Are the back and front signals evenly leveled in terms of volume (any difference in sound quality)?
- Jim
- Jim
geposted Thu 25 Apr 02 @ 10:36 pm
