Forum: Old versions
Topic: Cue Points Off
Why is it that when a song is playing and I hit ctrl + a number on keypad, then I hit the number in the keypad, the cue point is always off. Sometimes by a few seconds? I close all background applications and just have Atomix running. I use a Pentium III 933 Mhz w/384 megs or ram. Any suggestions?
Philip
geposted Sat 04 May 02 @ 6:31 am
HomeboyPRO InfinitySupport ManagerMember since 2003
I use the cue points every night with no problems whatsoever. Not saying that you are missing the spot but this could be your reason for this. There is a little lag but I have gotten used to when I need to set the cue point. My advice would be to set the cue points before you mix live. There are 2 ways to do this. 1. the way you have been doing it, but keep practicsing (bad spelling) 2. set the cue points while the song is paused and drag the rythm curve to the exact point you need it.
DJ Homeboy
geposted Sat 04 May 02 @ 8:58 am
