Forum: Old versions
Topic: Keyboard Shortcuts
Hi, I have a problem!! What are the keyboard shortcuts for the bass controls in atomixmp3?? Ive heard u can alter the bass via keyboard...Please help??
geposted Sat 04 May 02 @ 1:28 pm
You need to assign these shortcuts, they do not come preprogramed. Go into the options menu under shortcuts and sroll through the list you will find a bass up and a bass down, put these shortcuts where you think its the easiest and save your shortcuts. There are many shortcuts in there not offered on the skin, check them out.
DJ Homeboy
