Forum: Old versions
Topic: Gain/Volume Change
When I'm playing a song on A, at the volume I want and drag a new song from the playlist to B, the volume/gain on the song playing decreases noticeably. Can anyone tell me what I can do to maintain a constant volume/gain on the song That is playing. Many Thanx
geposted Fri 17 May 02 @ 5:05 am
Is Auto-Gain enabled or disabled when this happens?
Re:Volume/Gain question. The same sound/gain decrease occurs with auto gain enabled or disabled. It might have something to do with my 3d sound card.
Do you have it set to quadraphonic sound or whatever it's called so that the front and rear channels aren't adjusted or anything by the soundcard-drivers..
Front and rear channels should be equally amplified (=quadraphonic, four equal channels)
I noticed this in 2.0 not in 2.1 when 2.0 was in software mode. I haven't noticed it in the latest release.
DJ Homeboy
