Forum: Old versions
Topic: Will not play some MP3 files
Hey everyone,
I'm using an Intel PIII 1.1 GHz 256MB RAM laptop with XP pro. I've used PC DJ Red and Traktor previously. I'm finding about 15% of my files will not play on Atomix. They load to the side I choose but show no time remaining and will not play.
They play fine in Traktor and PC DJ Red and in Win Media Player. Any ideas??? All files are at 128Kbps or better with mixed version 1 and version 2 tags.
geposted Tue 04 Jun 02 @ 8:22 am
is it possible you are trying to play files that have been moved since the last time you let Atomix scan your drive. Rescan the drive, and try those tracks again.
Convert your "bad" mp3 files in .wav. Then, convert now these wav in mp3 (44.100/16 Bits).
Verify if your mp3 is in 44.100 Khz. Are 22.000 Khz files runs with Atomix?
I also believe that they are not being recognized cause you have probably moved your mp3's. As Impression said just rescan you hard drive.
DJ Homeboy
Either that or you renamed them. You have to rescan after re-naming too.
Thank you to all for the help. I was not aware that files needed to be rescanned if moved. I was working against myself by creating folders for songs I wanted to play later as I was going. They all work fine after rescan. Thanx again!!
Whoo Hoo!! Glad I could be helpful!
