Forum: Old versions
Topic: Using One Sound Card
Can anyone help me when using one sound card, with a one way channel how to listen to a speekers of oneside of the decks of automix, and using headset/earphones, to hear the other side of the decks of automix......plezzz help meeee.???
geposted Sun 23 Jun 02 @ 6:37 pm
you need to use a stereo splitter. plug one side into the speaker or mixer, then adapt the other side to your headphone. This will ONLY work with the full version. NOT THE DEMO!
When I do that It kind of works, but when I select a deck the sound switches in both the channels. Should you not be able to listen to the output all the time and just swith the monitoring? How?
As Impressionsdj wrote: You will need the FULL version to do that not the demo .-
Bye,
DJ Coco "Argentina"
lol, I think what I said was.... NOT THE DEMO!
Does it work on the cracked full version or only on the purchased version?
What a stupid question to ask in the forum.... The software costs only $60.00. Buy it, and then you will be sure.
