Forum: Old versions
Topic: Adding Winamp Visuals
Hi There
Finally got some time to try and organize some visuals via a projector for our mobile rig and intend to use the winamp plug in probably using the milkdrop 3d visual which is very reactive..
I have download the atomix winamp visual plug in and selected it in the options menu...
Not sure what to do now... do i look for the actual plugin within winamp or just point it to winamp itself ??
Or am i just being really thick today ???
Any help would be appreciated
Thanx team
Best regards
STU
geposted Sun 04 Aug 02 @ 10:09 am
I had some troubles figuring it out as well.. start the Winamp Vis-wrapper from Atomix' options-screen and in the popup that appears you should see the names of all you installed Winamp Vis' plugins..(that are correctly installed under your Winamp-path).
Just select one and see it go/flow.. I found it a bit unstable but had a blast with the AVS visualizing my Atomix test-session for about 15 minutes without any problems.
