Forum: Old versions
Topic: Loud at startup
Whenever I open atomixmp3 on my Win/XP box, it "automagically" turns my volume all the way up... Not good for my speaker system. Anyone know of a fix?
geposted Tue 20 Aug 02 @ 4:51 am
enable multi instance under "Configuration"
phatty720
dave
That's correct. When you enable the multi instance, Atomix will no longewr set your windows volume levels to maximum every time it's opened.
Just one more thought, the atomix team incorporated the auto volume on startup because inexperienced users continued to ask why there was no sound so for the experienced and people who just know what they are doing they have this feature disabled when multinstance is enabled. ALso if you opened atomix over and ever again maybe it would continue to try to raise the volume LOL !
.:DJ Homeboy:.
