Forum: Old versions
Topic: sound volume changed between channels
I tried to install sound blaster live value. I have an onboard digital sound card which I have been using, which has been fine. It wasn't broke but I tried to fix it. I installed SB as a back up and now it changed the volume outputs between my front and rear outputs on both the SB and my onboard card. I tried to uninstall all SB stuff and removed the card and my onboard card is still weak between the channels. I have it set up as a 4 speaker system and atomix set up as a digital card and with a mixer. There is a big difference between the channels.
geposted Tue 03 Sep 02 @ 6:27 am
try to change the sound configuration from the atomix and then bring it back to the 3d option "the 2 middle icons" it sould work
I appreciate your help, but I am confused. I'm sorry. Can you give me a dummy's version of what you suggested?
Again, Thanks.
Ok, after some sleep for a change, I know what you mean. I have it working for the 3-D card and the mixer settings. I also reloaded my sound card drivers and updated my DirectX to 8.1. No luck. The rear is quieter. I may uninstall atomix tonight and reload again to see if that works.
i have same problem!!!! when using my external mixer i have to put the gain on channel 2 up full and channel 1 on half!!!!!
do you mix with external mixer or you want it just for preview?
i mix with the external mixer
are you sure that the configuration in the atomix is right? it should work in my pc is working ok
