Forum: Old versions
Topic: Beatmix
How does the beatmix wizard work???? Do you have to press beatmix on both Turntables?? And does it automatically synch both songs????
geposted Sun 29 Sep 02 @ 11:49 pm
The magic button or sync button is used to line songs up automatically. After you have loaded a new song press the sync button to automatically allign the beat curves. Be sure to have beatmatch enabled or it will just play the song.
.:DJ Homeboy:.
And the way it works: if you're playing decks A and B and press the Magic-button on deck A it syncs A to B's BPM and beats and vice versa.
The Automix-button however tries to adjust both tracks for some unknow reason and what it basically does is a fixed lenght fade to the other song and automatically activates the sync-function mentioned above several times per second for the track that has the crossfader on it's side... not really that sweet an effect in general.
