how can i make my downloaded effects work? is it enough to put theml in the same folder as the atomixmp3.exe or is anything else needed? help me!
dj b_
dj b_
geposted Thu 27 Dec 01 @ 12:10 am
Put them in the effects folder....
geposted Thu 27 Dec 01 @ 4:32 am
Put the dll's in c:program filesatomixmp3effects (if you installed Atomix in c:program filesatomixmp3 . If not, you have to change this!). You've also got to use the FULL version of the program (not the trail!). To change the effect (well, to load the new one), you've got to press the button "open deck" in the effects section. Now you can enable the new effect (up to three).
Greetz, ikke
Greetz, ikke
geposted Thu 27 Dec 01 @ 10:33 am
