Forum: Old versions
Topic: Roll Back to 1.07b?
DJ CyderPRO InfinityModeratorMember since 2003
Team,
the current release is not stable on my system. Here are the the issues i'm having
1. Crashes on directoy change
2. sound card settings are lost and I have to reload them sometimes the sound quits all together and I have to restart.
3. using effects crashes the program after a little while
4. Heavy mixing/scratching/cueing results in a crash
All of these things Never happend in 1.07 b
That being said I'd like to roll back to the previous version. What is the best way to do this?
geposted Tue 30 Dec 03 @ 7:35 am
GwennPRO InfinityMember since 2003
You are sure it's not caused by your OS? because your are the only one user who have problemes.
If you want to return to v1.07b :
- Save data files : database, shortcuts, ...
- Uninstall VDJ v1.08
- Reinstall VDJ v1.07b
But I don't think it's the best solution. Have you contact the e-service?
Gwenn
geposted Tue 30 Dec 03 @ 9:50 am
