Forum: Old versions
Topic: Help shortcut keys
help
does anyone know where I can find shortcut keys for vitrual dj?
geposted Thu 08 Jan 04 @ 12:57 am
There is no where to download shortcuts! Make your own its easier!
Please Dont Post The Same Question In 2 Fourms
I don't know how to create shortcuts. How do I access a menu to do that.
Thanks
Philippe
its it the config panel of vdj
If you want to add a shortcut: Push the key wou want to assign and then selct the function you want in the menu
If you want to modify, select the key in the list and then click on "modify"
You can also assign more than one function on a same key.
