The patch on this site to update to the latest version of DJ Mix Station 2 gets you as far as V 1.07.
And ideas when the patch for V 1.08 (and all its bugfix and improved lovliness) will be posted?
I ask as the relevant page does not indicate the version you will be upgraded to and I wouldn't want to 'upgrade' my V 1.07 to V 1.07 again.
Thanks.
Thanks.
geposted Thu 08 Jan 04 @ 2:03 pm
I had a gander at eJay’s website to see if they had any patches for DJ Mix Station 2 feat VDJ (of course), but, get this, the only one they have is dated 18/09/2003!
What this boils down to, bugfix fans, is that the patch is for V 1.06!
Yes, that’s right, it doesn’t even upgrade to V 1.07, as that iteration was released on 11/10/2003.
Poor show eJay!
Doubt they’ll have an patch for V 1.08 any time soon.
The evidence:
http://www.ejay.co.uk/software/downloads.asp?psj=389
and
http://www.virtualdj.com/features/history.html
Poor show eJay!
The evidence:
and
geposted Fri 09 Jan 04 @ 4:42 pm
We will fix the problem on the update page asap. Thanks for the report.
geposted Sat 10 Jan 04 @ 4:30 pm
Hi Yan-X.
When you say, “fix the problem on the update page asap”, do you mean that the patch will be for the upgrade to V 1.08?
Also, will the patch actually tell you the level of upgrade that will be attained (where it does not presently)?
PS – Is the V 1.08 patch actually ready for posting up?
PPS – I’ve fired off an email to the technical support team at eJay detailing the issues raised in this thread and others. I’ll post up their response when (and if) I get one.
geposted Sat 10 Jan 04 @ 10:03 pm
