Forum: VirtualDJ Plugins
Topic: Broadcasting?¿?¿?¿
Can I broadcast on a site that I created?¿?¿?¿
geposted Sat 17 Jan 04 @ 5:06 am
DJLAu : if all music are of you, you can, else you use others musics you can't cause it's not legal.
Gwenn
install shoutcast-dsp-1-8-2b-windows.exe
and
shoutcast-1-9-2-windows.exe
from "u guest it" www.shoutcast.com
(on site click download , wanna be a dj and wanna be a server)
there u find the files
then after install start the shoutcast server
(start-->programs--->shoutcast-dnas )
then click edit config (on the top right)
then a text file pops up
edit a password
then close and restart server again
now start ur winamp (2)
richtclick it to configure the options/preferences
there at PLUGINS u see DSP/effect
select it and there u see nullsoft shoutcast source dsp
select that one and again a window will pop up
(ur shoutcast source)
here u click the OUTPUT tab and put the same password as u used in the server b4
put ur ip addres
the yellowpages tab u can put ur radio tag
now select encoder and select the bitrate ur stream can handle
now back to the output tab again to see in ur status if u are sending if not u shoult try disable ur firewall
now u got ur radio station running
just to get otther ppl to ur station send them the link like this
http://yo.ur.own.ip:8000/listen.pls and winamp would start if they click the link
to check more things like listners and stuff
you just type in ur browser http://yo.ur.own.ip:8000 and press enter
now u can login as admin but u should set a password for that also
look again at the server (edit config) and look for ADMINPASS
ok u figure it out urselff
--------> now to get ur console broadcasting
just select plugins from virtual dj and select (probably) C:\Program Files\Winamp\Plugins\dsp_sc.dll
so the DSP_SC.DLL as plugin and ur console should be broadcasting if u click the broadcast button ( duhh) ;)
hef phun and let me know when u start spinning ;)
quel plugin utilisé pour pouvoir emmettre svp car je ne trouve pas
and what about VDJ radio, are you paying something in order to be "legal" ?
maureldavid
Ecris en anglais sur ce forum s'il te plait. si tu prefere parler uniquement français va sur le forum français tu auras une réponse tout aussi claire!
http://www.virtualdj.com/forum/topic.html?forum=29
Just wrote to tell him to go on french forum if he want's to speak french.
Hi, I've got a sofware called "WEB RADIO RECORDER". Can I use it to do broadcasting on DJMIX station 3 full version???
"WEB RADIO RECORDER" this name seems to say that this program is make for record other web radio and not to realize a web radio.
Hey,i`am a rookie in disk joking and i really want my friends to hear when i try new beats(live) and i don`t know how to broadcast..please someone help me .Let the sounds lead your life.
MicsuniKA: what is the version number of your trial vdj?
(because broadcast evolved and it is really simple since VDJ 2.1)
ive been looking at various ways to broadcast,
i think ive worked out how to broadcast using winamp and edcast, which i can connect with and streams through stream.ogg
havnt checked if it works using other computers yet,
but im wondering can i do the same, just not using winamp and using virtualdj instead?
if so
could someone give details on how to do so,
i looked for plugins in virtualdj, to try open the edcast plugin, but couldnt find a menu for plugins
anyone know how?
thanks
VirtualDJ has been designed to stream to Shoutcast servers; you can't copy across another plugin to do anything else unless it has been specifically written for VirtualDJ.
I currently use SAM broadcaster to stream music online which goes through a site called clubrlc.com they use a shoutcast server. How do I link my vdj to that current server. http://clubrlc-a.mixstream.net:8004 if anyone wants to listen. The reason I want to do this is that I want my friends from this game I play online to hear me mixing my music. Can anyone help?
OK, i'll post here becasue my question is kinda related...
Can I broadcast to my server using Virtual DJ DJC Edition?
I know that there is no broadcast option in this version of Virtual DJ, but is there any program
that i can install so i would be able to broadcast music from VDJ to my server?
Thanks in advance!
When I click start recording on broadcast mode it gives me a URL to go to but it says that it can't connect to the URL every time. I've tried converting it to mp3 but it still wont work
