Forum: Music discussion
Topic: Help with Recording
I need a program too record a mix on atomix with and Preferably something free...
geposted Thu 24 Jan 02 @ 3:11 am
First of all, there is a recorde built into atomixmp3. You just click on the microphone symbol to access the record menu, then click record, and give your recording a filename. If for somereason this does not work, try using a sound recorder that came with the software on your soundcard drivers and applications cd. If you have a soundblaster live!, then you most likely can use the program called "Creative Recorder." If you still cannot find a recorder, go onto downloads.com and search "sound recorder." I hope this helps, and good luck with your mixing!:)
geposted Thu 24 Jan 02 @ 3:17 am
