Forum: Old versions
Topic: Using two soundcards in a Laptop
I ppl, I just began using my Atomixmp3 (v2.1) with my laptop and I would like to share my config with you all, because it works quite well. I'm able to use two sound cards just by using the one onboard the laptop and by connecting to the usb port a TELEX P-800. It's cheap and with works just fine!!!!
geposted Thu 17 Oct 02 @ 6:21 pm
I bought a plantronics USB headset microphone that can be set up as a second soundcard for cueing purposes. All for $59.99.
Will it work with the iMic USB Audio Interface from GriffinTechnology as well?
I also use the telex audio device as a 2nd sound card, with the laptop. It does work fine!
I've just bought the full version of atomix and the iMic usb audio interface (www.griffintechnology.com 35$) to use as a 2nd sound card on my laptop, and it works great!
But, I don't know how can I set the volume for the premonitoring in my headphones (it's too loud). If someone can help me...
