Is there a way to put track mark on a mix session , without having a gap in the music.
geposted Sat 19 Oct 02 @ 3:45 am
in you cd ripping program you need to select "disc at once"
geposted Sat 19 Oct 02 @ 2:08 pm
If that doesn't work go into options of the recording settins and choose 0 seconds between tracks.
.:DJ Homeboy:.
.:DJ Homeboy:.
geposted Sat 19 Oct 02 @ 10:28 pm
What type of software do you use for your cd burner?
I got a HP Burner and just the software that cme with it and the "disc at once" option is not there and the other option I can't find. Please help.
DJ E-Double
DJ E-Double
geposted Sun 22 Dec 02 @ 4:35 am
You should get Nero burning Rom... to me it's the best software u can get... and HP is one of the crappiest.. so get a trial at ahead site and if u like it, then buy it... it's kinda large to download if u got a slo connection, (12 megs) but it's the best u can get... it burns from data to vcd to music cds, to DVD if u goy a DVD burner device)
mhhh this looked like a commercial.. sorry, but that's what i can tell from now.
Oh yeahh.. u could also get EzCD creator (roxio's, i think) but it's harder to burn mixed cd's on it, or also neroMix, also from AHEAD.
Hope this is useful to you!!!
geposted Thu 26 Dec 02 @ 10:47 pm
