After installing 1.08 i found several bugs (which i already reported) except for thisone:
there is no headphone output in the hercules-console! it was working fine with the version shipped with Herculesconsole.
I found some headphone sliders in the pioneer-skin, but when sliding the headphone sliders, it drops some of the channels of the MAIN-audio output (nobody wants that >:-[ )
Dear Support, please fix this.
geposted Mon 19 Jan 04 @ 3:05 pm
Hi,
It's a bug in the DJ Console.
Since the "VDJ special DJ console edition" is dedicated to
the DJ console, the software has been "adapted" to this
bug ; but the full version, which has to work with
all generic 5.1 soundcards, it's not so easy to correct.
But the devteam is working on a solution.
To wait for the fix, I can suggest you 2 things :
* to use the 5-6 rear output of the DJ console instead of
the front 3-4 headphones jack (this is the bug)
* to use the special DJ console edition with the patch
V1.08
Hope this helps,
DJ LARIOS
V1.08
Hope this helps,
DJ LARIOS
geposted Thu 29 Jan 04 @ 11:03 pm
ok.. i could use a convertor to put my headphones into the read 5-6 output. in case i have no external mixer around.
but the rear output is much weaker for phones than the output in front.
we'll just have to wait for the fix. thanx anyway
geposted Tue 03 Feb 04 @ 12:02 pm
