When using the Audigy 2 NX soundcard plugged (connected to PC via USB 2.0 port), I get no sound out of my headphone when headphones are plugged into rear speaker output. All audio (main and queuing are sent to the front speakers). I am using v1.08. I tried configuring VirtualDJ to use "Primary Sound Driver" and "Soundblaster Audigy 2 NX". I managed to work around the problem by enabling my PCs integrated soundcard and using that to drive my headphones. However, others may not have integrated soundcards. Other than that, works like a charm! Keep up the good work.
geposted Tue 20 Jan 04 @ 3:29 am
My Bad. Appears to be something wrong with surround outputs with my soundcard. The card is routing the audio to the wrong outputs. Virtual DJ appears to be working fine.
geposted Tue 20 Jan 04 @ 4:19 am
