Topic: recording my mixes
i have read alo and yet to find the solution to my problem. i have a sblive card with an external mixer, when i go to record on ch1 and montoring ch 2 they both records. just want to know what config i need to setup. another then is i have 2 sblive card both i try to install them both and i get the bluse screen of death when i start my pc
p4
256ddr
1.8
2hd40/80gig
sblive
sblive vaule
geposted Fri 01 Nov 02 @ 12:55 pm
Sorry man: you can't use an external mixer or use preview function without the full version of atomixmp3.
Atomixmp3 demo version can record your mixes but it adds empty spaces during the recording.
Peroz
i have the full verison
Login then! You'll get better assistance. If you're using an external mixer you need to record from the mixer output.
If you record using external mixer, you need to have 2 soundcards. One for sound output and one for recording using line-in. I tried using a single soundcard for both playback and recording at the same time and got an echo effect.
