- The fader is decreasing sound level before it comes to the middle position, the sound level should remain stable until you go over 51%
- Try to drive a second sound card for headphones, otherwise you will never be able to mix properly
geposted Fri 01 Nov 02 @ 11:34 pm
well you can change the crossfader behaviour in the options and you can use 2 soundcards in the "FULL" version not cracked as it still wont work!
geposted Sat 02 Nov 02 @ 1:40 pm
