Hi,
What is the best professional soundcard with two stereo outputs, recommended for use in a PC with Virtual DJ? It could be internal or USB 2
How about the new Terratec USB Phase 26 ? Have you tried it with Virtual DJ?
Thank you.
Elvert
Thank you.
Elvert
geposted Wed 21 Jan 04 @ 1:10 am
A user (I don't remember his name) got one he's happy it woks perfectly with vdj. If the usb doesn't matter i advice the phase 28 which is 24bit/192KHz depth.
geposted Wed 21 Jan 04 @ 1:52 am
Just to thank you for your reply. Your tip about Terratec Phase 28 was also appreciated.
Elvert
Elvert
geposted Wed 21 Jan 04 @ 3:09 am
M-Audio Audiophile 2496 - you'll never look back.
geposted Wed 21 Jan 04 @ 10:09 am
Hi:
Did do you have used them live? and what about the headphones?
I'm actually using a Audiotrak MAYA 7 soundcard and i can't do any preview of the songs.
Can you help me with that issues?
Thank you
Thank you
geposted Wed 21 Jan 04 @ 4:25 pm
Hi
I would appreciate to receive a reply from Yan ( Virtual DJ team) about the best professional soundcard with two stereo outputs.
Thanks
Elvert
Thanks
Elvert
geposted Wed 21 Jan 04 @ 5:03 pm
I am using my Motu 828 firewire soundcard it is working great. I wish VDJ had ASIO support. So I could route my Mic inputs to record. I am using a Peavey Mixer an two output chanels on my motu 828 . I can use The other ones if I want to use muti instances of VDJ.
geposted Fri 23 Jan 04 @ 3:21 am
Hi,
I use the USB Sound Blaster Audigy 2 NX.
Please, find below the url link for more information
http://www.creative.com/products/welcome.asp?cat=2
Regards
Laurent
Regards
Laurent
geposted Fri 23 Jan 04 @ 1:31 pm
Im thinking of gettin a neww sound card this weekend, how doe s the SB Extigy compare? if not, what would be the best quality, but not gonna empty my wallet too much
geposted Sat 24 Jan 04 @ 12:23 am
I was just at best buy and they had an audigy or extigy for 64.99 CAD with usb 2.0 :)
geposted Sat 24 Jan 04 @ 1:22 am
Home, how many times I gotta tell you! Stay away from Best Buy! They ripped me off for 900.00 + 200.00 for an extended waranty for a digital camcorder that lasted just over 6 months... They refuse to fix or replace it! UGH!!
geposted Sat 24 Jan 04 @ 3:34 pm
