Would'nt it be graet if you actually have a preset button for your songs in the record case. Often at times the equalizer level will have to be changed because not all music are at an equivalent Hi,Med and Lo level. If there can be a button that will save a preset for the song so that everytime you load the song you dont have to worry about the equalizer unless you just want to change it for that instance.
geposted Sun 03 Nov 02 @ 12:22 am
Good Idea !
geposted Sun 03 Nov 02 @ 9:15 am
That is a good idea! But on top of that it'd be nice if you had an equalizer. Not just Hi, Med. & Lo. but somethin' to precisley match both decks! Especially when you download them songs that sound real bad & you wanna make them sound normal! Justa thought!
geposted Mon 04 Nov 02 @ 5:14 am
