Forum: Old versions
Topic: groove box
before i buy atomix,can i use an external mixer and a groove box with it?
geposted Sun 03 Nov 02 @ 10:53 pm
the full version of atomixmp3 will allow you to use two soundboards or a 3D card. thus, you can have each track on a seperate channel as if you were using CD decks.
if you had a three or more channel mixer you could certainly use that with atomixmp3 and your groovebox, assuming you had:
a) full version
b) two sound boards -or- a 4-channel card (like the SB Live)
c) the proper mixer
d) the cables to hook it up
Also, with the full version, you can split the output to 2 channels without the 2nd sound card. With 1 sound card you use a stereo splitter, one side of the stereo signal becomes deck 1 and the other side becomes deck 2. It's mono output, but it's full mono, and sounds about as good as the 2 sound card set-up. If you are using a mixer, and don't have a 2nd sound card I recommend you do it this way.
