Forum: VirtualDJ Plugins
Topic: Reversed Brake Effect
is there a reversed brake effect? cause when i mix songs and use brake, i dont always cut to a diff song, i sumtimes keep it going, and starting it again and pulling the volume control up dosent sound too good, so could someone PLZ make this?
CyA
geposted Mon 04 Nov 02 @ 11:03 am
It's not possible since one cannot stop/rewind the audio stream.
I am working on a backspin though, but that is a final (song-ending) effect. I'm working on 2 versions, a single backspin, and then one which repeats the backspin on the beat and fades out (a bit like the backspin with echo which is used by Roger Sanchez now and then - I guess it's one of the effects on a Pioneer CDJ-1000)
Kind regards,
DJ Corpse
geposted Mon 04 Nov 02 @ 3:52 pm
k thx newayz
CyA
geposted Tue 05 Nov 02 @ 9:55 am
