Topic: echo effect needed
I am a dj i want to get an echo effect when i speakwith the mic in my sesions, could anybody help me? If you know any program that do echo effect please tell me thank you
geposted Tue 05 Nov 02 @ 11:29 am
atomixmp3 does not work with microphones.
you can record your voice and then use acid pro and use simple delay to add echo.
Just downloaded atomixmp3 after seeing a friend run it on his PC.
Looks great bit of software, or at least it would if I could use the thing.
Can someone tell me where I get my serial number from that you have to enter the first time you use it ?
That's sent to you via e-mail right after you pay up the $60.00 bucks to buy it.
$60.....
well worth it!!!!!!!!
a snip at the price!!!!
Later
Liam
