Hi all, I'm trying atomix...i want just to know if is possible to select the A and B buttons togheter to listen the mix in the headphones other than in the speaker... I'm using 2 sb live!
Now I can select only one of the two buttons so I can hear the mix only in the speakers and in the headphones in can hear only one of the two songs that i've loaded in atomix...
I hope you've understood my question :)
geposted Thu 07 Nov 02 @ 1:19 pm
Yes. There is a preview-slider that lets you prelisten both songs together on your headphones. This slider is not on the default skin, but you may find it on several new skins in the add-ons-section.
I also believe that this feature is limited to the full version of Atomixmp3.
Jim Nordic
Jim Nordic
geposted Thu 07 Nov 02 @ 1:44 pm
