for some reason I can't seem to load any wma files or play cd's.
Does one have to upgrade to the pro version of the software to use these features?
geposted Thu 22 Jan 04 @ 1:21 am
As far as i know, i was able to play wma/cda while trying out the demoversion. Does VDJ refuse to read your cd's, where does it go wrong?
geposted Thu 22 Jan 04 @ 8:04 am
henrooo:
Please, install Windows Media Player 9 to be able to read wma files.
For CDs, do you have windows98 ? Win98 users seems to be unable to read cds, but I not sure.
geposted Thu 22 Jan 04 @ 8:50 am
... and keep in mind that you will be never be able to uninstall this ms crap...
wont it be enough to install some wma - drivers ??
geposted Thu 22 Jan 04 @ 1:15 pm
DJ CannonBall, Sharan,
it is also possible to install the Codecs of media player 9. It is true that when windows media player 9 is installed, you only get it away by formattiong your drive. I don't like mediaplayer 9 while I have VDJ! So I installed only the codecs which works ok.
You are able to download the codepack from Bill at:
http://www.microsoft.com/downloads/details.aspx?FamilyID=06fcaab7-dcc9-466b-b0c4-04db144bb601&DisplayLang=en
Ewout
Ewout
geposted Thu 22 Jan 04 @ 9:29 pm
Thanks,
Installing media player 9 worked for the wma files. But I still doesn't allow cd tracks to be dropped.
I read somewhere on on of the forums that I need to be running on XP ( current OS Me) for VDj to work with CD's.
anyway thanks a bunch. It seems that every time I use the dj console I notice there's something new wrong with it. The right jog wheel doesnt work when you turn it anti-clockwise. it simply reacts as if it was turned clockwise.
Oh well,
have send it back I guess.
Anyway,
Thanks for all the help.
Oh well,
Anyway,
geposted Thu 22 Jan 04 @ 11:38 pm
