The base on the equaliser is too high , sounds like about 100mhz or so, it should be set at 60mhz like normal equipment and there should even be 5 chanels.
Also needs a pitch bend facility
Otherwise ithe program is perfect for mobile disco use and suchlike.
thanks
kevin steyn, South Africa
thanks
geposted Wed 13 Nov 02 @ 6:52 pm
You can use the right mouse button to get your pitch bend... it moves the pitch to where your pointer is located until you release it. It takes just a bit of getting used to, but it's actually way more useable then a standard pitch bend... in my opinion.
geposted Wed 13 Nov 02 @ 8:26 pm
'Q' and 'W' button ...
geposted Thu 14 Nov 02 @ 9:22 am
The bass should refer to hard bass not soft. Hard bass is needed for outdoor use.
thnky,
thnky,
geposted Wed 27 Nov 02 @ 2:49 am
