A jog dial for visual wave cueing would help an otherwise near perfect product!
geposted Sun 17 Nov 02 @ 11:35 am
well, Atomix has visual wave cueing... what do you mean with "jog dial"?
geposted Fri 22 Nov 02 @ 10:48 pm
Do you mean support for something like this: http://www.griffintechnology.com/audio/pwrmate.html or a visual jog-wheel on the screen for scratching/searching?
geposted Wed 04 Dec 02 @ 10:38 am
djGee: i completely agree.. a jog wheel just like that in virtual turntables (vtt) then it would rock, also a pitch up / down button that changes the pitch every so slightly
geposted Fri 06 Dec 02 @ 10:04 pm
q and w are bend buttons
pitch up -->+ (on the numpad)
pitch down --> - (on the numpad)
to have a smaller pitch up/down use the shift button together with + or - ...
geposted Sat 07 Dec 02 @ 3:28 pm
