My favourite mixtechnique is to use the smartrepeat
on one or both songs, then applying autowah och cutoff
on one while mixing to the other..
BUT. have you got any tips how to stop the smartrepeat
on the current playing track without getting it out of sync
with the regular track?
(i.e. you smartrepeat a song every 2 beats and then you
want it to run natural but the loop and the track gets out
of sync).
of sync).
geposted Fri 29 Nov 02 @ 3:37 pm
Hi, u can using my shortchut, no loop required, you just have to push a button to made two beat loop and after two beat end you have to push it again in time, and and let it go if you want to finish your smart repeat. If you using loops, you can push release loops to finish.....
TQ.
TQ.
geposted Mon 15 Dec 03 @ 12:56 pm
