Topic: Mp3 Gain V. 2.2
I had the program "MP3 GAIN" to check all my songs, afther that i let atomixmp3 analyze all my re-gained mp3's.
But all the work whas for nothing still the volume level is going up bit by bit when i use auto gain, and when i don't the volume level is going up and down!.
Please team tel me that in V. 2.2 the autogain is replaced by a good dynamics processor or make it possible to use the Dsp plugin Audiostocker po.
Greetz,
Salva
geposted Sat 07 Dec 02 @ 10:50 am
I use mp3 gain too.
Try to disable auto gain and check in external mixer the vu meter. I thing the problem is atomix has analyse the mp3 before you use mp3 gain.
Remember, analising the song sets sort of a base level... Atomix has a much fuller look at it once it's played all the way through. Even a song that you have scanned will still change a bit as it plays through for the first time. However, it's been my experience that once the song has been fully played through once, the gain will stay the same from then on.
