Topic: SOUND EFFECT PLAYER
ANY ONE KNOW A GOOD DIGITAL SOUND EFFECT PLAYER I CAN USE WITH ATOM MIX AND A PROGRAM THAT CAN ECHO MY VOICE ??? PLEASEEEEEEEEEEE !!!!
geposted Wed 11 Dec 02 @ 6:54 am
1) we can read and small letters also.Most of us do not have a problem with vision.So you can turn the caps off
2) Depends of if you wonna do the effects live in that case the easiest way is to use the effects of your soundcard or bypass it from a sequinser like Qbase and use the effects of it (you will need 2 soundcards for this job) If you want to add effects after you can use Sound forge 6.0 which has a good features for adding multiple effects in preview in a chain way.
