The title says it all. Has anybody else had this problem and if so what is the solution. Hard to work if the software fails.
geposted Tue 17 Dec 02 @ 11:50 pm
1st you had to post this at technical support.
2nd you have to tell us your configuration
3rd you have to search the forum before you post.there are a lot of answears.If you dont find anything helpfull
4th e-mail services of atomix.
geposted Thu 19 Dec 02 @ 1:33 pm
