I am a demo user and after every 15 minutes an atomix banner pops up pausing my mix. Is there anyway around this?
geposted Wed 18 Dec 02 @ 2:34 am
Yes there is a way around your problem.
BUY IT!
It is designed to do that as a demo, I am pretty sure that is why they call it "a demo".
This is not ment to be a smart ### answer, just telling you the facts.
BUY IT!
geposted Wed 18 Dec 02 @ 3:44 am
Yep - the answer is to buy it. It's a bargain and if you are using it enough that the pop-up is annoying you, then it will be well worth it.
Cheers,
Jack.
Cheers,
Jack.
geposted Wed 18 Dec 02 @ 11:28 am
