Forum: Old versions
Topic: Tempo doesn't reset in "end of song" automix mode
Hello,
In automix mode, when using option "to the en d of the song",
the tempo doesn't reset automatically.
This bug seems to be easy to correct but it hasn't been
corrected in V2_2.
Since it has been report a long time ago, I ask myself if
it has really reached developpers's ears .....
Happy Christmas,
DJ LARIOS
geposted Tue 24 Dec 02 @ 8:50 am
DJ LARIOS
I Have try it and if you put the option AutoReset (of course) it is no probleme
mUd-V
Hi,
It doesn't always work, even if you chose (of course)
the "Automatic return". Try it with more songs.
Note that if you chose "last beat" in the crossfading
options, the return works very well ; the problem only
occurs when you chose "end of song".
DJ LARIOS
