Anybody!!! I need help to download samples for the atomix.My question is simple where can i get a few cool samples?
geposted Thu 26 Dec 02 @ 4:22 am
Not at a computer at moment to tell you a certain site. but will post again later if I remember (I am getting older).
In the mean time, look around the net. (do a search on google)..... any .wav file will work (I think as long as it is 32bit)....don't think (8 or 16 bit will show up).... download wave file .... put it in a directory and then click on the arrown on the sample you want to change and direct it to that folder and file. If the wave is the lower bit type will need to prob. convert it to 32 bit with a program like cool edit.
Hope this helps Carman
geposted Thu 26 Dec 02 @ 11:52 pm
goto my new site:
its brand new and features mixes with how-to guides.. it'll b mad once it gets going and people start submitting their work to it... :)
*As posted before, please do not submit url's to other sites
geposted Thu 16 Jan 03 @ 11:21 am
