I just installed the 2.2 patch, and atomixmp3 will not open. It says "invalid skin file". I was using the Multiview Skin in version 2.1. Help!!
geposted Fri 27 Dec 02 @ 3:15 am
Try to rename a skin in default.
I mean rename the bmp file to default.bmp and the xml file to default.xml.
If it does't work email service@atomixmp3.com
geposted Fri 27 Dec 02 @ 8:56 am
when it's installed it goes back to the default skin. If you removed or deleted the default skin before opening the program that's the error you will get. Put the default skin back in place, (xml & bmp) then open it up. Once it launches, then you can change skins.
geposted Fri 27 Dec 02 @ 3:24 pm
Made the register of atomix mp3 v2.2, lowered it of the InterNet, installed pach, I placed the Serial Number, and when I go to only execute it it appears the top with the image "Atomix MP3". It will be that it is some problem of Skin? or it is a problem in the Database? I wait a clear reply, or my money in return.
geposted Wed 01 Jan 03 @ 8:30 pm
Write to :
Don't wait around on forum for your money, think you'll be waiting a long time. However, if you write to above address you'll have your problem take care of and will not need a rebate.
geposted Wed 01 Jan 03 @ 11:30 pm
