Is there a way to automate the choosing of mp3's, the playing, and the cross fading between tracks?
What I would like to do is have a timer where if it is between 9am-5pm mp3's are played from c:\busnesshours
5pm-6pm mp3's from c:\myrock
ect....and so on....
Also I would need to have everything broadcast logged.
I am doing this for my university,so if this is possible then I'd like to know how. once I have it functioning perfectly, my school will register it.
Thank you for your time.
geposted Tue 31 Dec 02 @ 8:16 am
Sir,
You could set it up using a playlist. You would need to calculate the lengths of your songs to know at what time exactly the mood would change. You can set the crossfader to react differently and change the mix lengths. If you need more info feel free to mail me at djhomeboy@atomixmp3.com
geposted Tue 31 Dec 02 @ 8:27 am
Unfortunatly a play list isn't what I'm looking for. If it can't automatically generate, and load a play list at set points, then I will just have to keep looking and just use winamp. Thank you for your time.
geposted Tue 31 Dec 02 @ 5:20 pm
