Forum: VirtualDJ Skins
Topic: Skins that i download
why doesnt some skins work ?? when i load one skin, then suddenly atomix shuts down, why ??
Thanks.
geposted Wed 01 Jan 03 @ 7:50 pm
mixalisPRO InfinityMember since 2003
Download v2.2
geposted Wed 01 Jan 03 @ 8:35 pm
ok thanks! but where ??
geposted Tue 14 Jan 03 @ 11:38 pm
Y WHEN I DOWNLOAD SKINS I TRY AND INSTALL IT IT COMES UP WITH MEDIA FORGE OR RUNTIME ERROR
geposted Sun 26 Jan 03 @ 10:47 pm
mcs-itPRO InfinityMember since 2003
geposted Tue 28 Jan 03 @ 8:33 pm
i downloaded skins, put them in my skins folder, but still can't open them nor does it show in the automix to chose from. what am i doing wrong? help.
geposted Fri 31 Jan 03 @ 7:28 pm
how do I open the skin I've just download
geposted Fri 31 Jan 03 @ 8:14 pm
I DONT KNOW HOW TO ADD A SKIN TO ATOMIXMP3 AFTER DOWNLOADING IT WHAT AM I SUPPOSED TO DO TO MAKE IT WORK.
geposted Sun 09 Feb 03 @ 6:32 pm
CHarmanPRO InfinityMember since 2003
Just Download your skin. (make sure it matches the verison of atomix you have) 2.2 is backward compatable.
Use an unzip program... like win zip or microsofts unzipper and put the files you find after unzipping and put them in the skins directory of Atomix.
When you start up atomix...go to confg. window ...and click on change skin. Pick out your new skin and mix away.
Carman :)
geposted Mon 10 Feb 03 @ 7:10 am
How Can I Make My Own Skin????
geposted Sat 15 Mar 03 @ 11:28 pm
